Base Feature
I have sheetmetal with a flat pattern. I want to save the flat pattern to a separate file and create a base feature from the part copy.
This gives a error message with the follwing error message {System.InvalidCastException: Interface not supported (Exception of HRESULT: 0x80004002 (E_NOINTERFACE))
Can someone point me in the right direction?
 privatevoid Test()Application app = null;;Documents documents = null;SheetMetalDocument sheetmetal = null;Models models = null;Model model = null;Constructions constructions = null;FlatPatternModels flatpatternmodels = null;FlatPatternModel flatpatternmodel = null;try
 // Connect to a running instance of Solid Edge
app = (SolidEdgeFramework.
app.DisplayAlerts =
 Application)Marshal.GetActiveObject("SolidEdge.Application");false;// to be sure it is a sheet metal document
sheetmetal = (SolidEdgePart.
flatpatternmodels = (SolidEdgePart.
flatpatternmodel = flatpatternmodels.Item(1);
flatpatternmodel.SaveBody(
SolidEdgeConstants.
SolidEdgeConstants.
 if (app.ActiveEnvironment == "SheetMetal")SheetMetalDocument)app.ActiveDocument;if (sheetmetal != null)FlatPatternModels)sheetmetal.FlatPatternModels;if (flatpatternmodels != null)if (flatpatternmodel != null)"c:\\tmp.psm",DocumentTypeConstants.igPartDocument,ParasolidVersionConstants.seParasolidCurrentVersion);// Get the documents collection.
documents = (SolidEdgeFramework.
documents.Open(
constructions = (SolidEdgePart.
models.AddByConstruction(constructions.Item(1));
 Documents)app.Documents;"c:\\tmp.psm", Missing.Value, Missing.Value, Missing.Value,Missing.Value, Missing.Value);SheetMetalDocument)app.ActiveDocument;Models)sheetmetal.Models;if (models != null)Constructions)sheetmetal.Constructions;if (constructions != null)catch (Exception ex)MessageBox.Show(ex.Message);finally
app.DisplayAlerts =
documents =
sheetmetal =
models =
model =
app =
}true;if (documents != null)Marshal.ReleaseComObject(documents);null;if (sheetmetal != null)Marshal.ReleaseComObject(sheetmetal);null;if (models != null)Marshal.ReleaseComObject(models);null;if (model != null)Marshal.ReleaseComObject(model);null;if (app != null)Marshal.ReleaseComObject(app);null;
SolidEdgeFramework.
SolidEdgeFramework.
SolidEdgePart.
SolidEdgePart.
SolidEdgePart.
SolidEdgePart.
SolidEdgePart.
SolidEdgePart.
Posted by: Rob Flippo
Post date: 9/9/2009 9:23:56 PM
RE: Base Feature
The code was not readable, this time correctly formatted.
privatevoid Test()
SolidEdgeFramework.Application app = null;;
SolidEdgeFramework.Documents documents = null;
SolidEdgePart.SheetMetalDocument sheetmetal = null;
SolidEdgePart.Models models = null;
SolidEdgePart.Model model = null;
SolidEdgePart.Constructions constructions = null;
SolidEdgePart.FlatPatternModels flatpatternmodels = null;
SolidEdgePart.FlatPatternModel flatpatternmodel = null;
try
  app = (SolidEdgeFramework.Application) Marshal.GetActiveObject("SolidEdge.Application");
  app.DisplayAlerts = false;
    sheetmetal = (SolidEdgePart.SheetMetalDocument)app.ActiveDocument;
       flatpatternmodels = (SolidEdgePart.FlatPatternModels)sheetmetal.FlatPatternModels;
             flatpatternmodel.SaveBody("c:\\tmp.psm", SolidEdgeConstants.DocumentTypeConstants.igPartDocument, SolidEdgeConstants.ParasolidVersionConstants.seParasolidCurrentVersion);
             documents = (SolidEdgeFramework.Documents)app.Documents;
             documents.Open("c:\\tmp.psm", Missing.Value, Missing.Value, Missing.Value,Missing.Value, Missing.Value);
             models = (SolidEdgePart.Models)sheetmetal.Models;
             if (models != null)
               constructions = (SolidEdgePart.Constructions)sheetmetal.Constructions;
   finally
     app.DisplayAlerts = true;
       documents = null;
       sheetmetal = null;
     if (models != null)
       models = null;
     if (model != null)
       model = null;
     if (app != null)
       app = null;
Post date: 9/10/2009 11:01:15 PM
