Basic help!
Hello im new to this forum, and programming in general. Ive worked with soild edge for a while tho.
Ive read the VB soild edge tutorials and im still have problems with the basics and syntax.
lets say i have 4 end points that i know the cordinates to how would i plot these points (in a sketch) and connect them with a line and protruted the skecth and "x" amount of distance?
I have visual studios 2005 and soild egde V19; thanks in advance
John Wong
Posted by: John Wong
Post date: 1/14/2008 12:31:48 PM
RE: Basic help!
John,
Are you using VB6 or VB.NET? I don't have an example for end points.
If you're just trying to learn, I'd suggest that you go to my Downloads page and download the "Solid Edge Developer Conference Material (2005 - 2007)" material.
Posted by: Jason Newell
Post date: 1/15/2008 3:30:46 PM
RE: Basic help!
I have VB6 and VB.NET(which do you prefer), I really need learn how to create lines with end points; if anyone knows how to i would be grateful
John Wong
Post date: 1/23/2008 10:46:49 AM
RE: Basic help!
I was looking through the soild edge "SDK" folder and i found something called the "ngon polynomal" this is much like the project im working on, but i rather have uncommon shapes, any ideas?
john wong
Post date: 1/24/2008 12:37:44 PM
