Batch MAcro
    Any body know to create program in VB to convert the ProE part file to Para Solid file. Then from parasolid to solid edge part file.Please help me.
Thanks In Advance,
Aravind
Posted by: aravind vijayan
Post date: 9/23/2010 10:44:57 PM
RE: Batch MAcro
Aravind
I'm using ST2 and it appears that you can open a ProE file directly.  You can use objDoc.SaveAs() to save it in any format supported by SE.
Posted by: Terry Tyson
Post date: 9/24/2010 3:16:28 AM
RE: Batch MAcro
If i do so that converted parasolid part not able to open in solidedge.
Aravind
Post date: 9/27/2010 1:43:03 AM
