BeforeDocumentClose
I am implementing code in the BeforeDocumentClose section of an addin. Can I stop Solid Edge from closing the file, if my logic determines I need to?
Posted by: Kevin Haen
Post date: 2/28/2006 8:09:33 AM
RE: BeforeDocumentClose
Kevin,
I've tried about everything that I can think of but I can't stop the save. You might submit an IR to GTAC and ask if it's possible.
Posted by: Jason Newell
Post date: 3/1/2006 9:33:04 PM
Here is the response I got from GTAC:
IR #: 5417810
*** Date & Time: 02-mar-2006 08:40:32 User id: kjrangan ***
No. You cannot terminate the closing process by trapping this event. When your event function returns Solid Edge will continue closing the document.
Post date: 3/2/2006 3:33:43 AM
Kevin,
try to detect the CommandID for DocumentClose in the BeforeCommandRun-Event, and terminate it with something like "killCommand".
Sub killCommand()
Dim objCommand As SolidEdgeFramework.Command
Set objCommand = seAPP.CreateCommand(seTerminateAfterActivation)
Call objCommand.Start
Set objCommand = Nothing
End Sub
Sorry for the Vb6 code.
Jürgen
Posted by: Sachin Chougule
Post date: 3/7/2006 12:24:49 AM
