Beginner Programmer Help
I am a beginner programmer trying to learn VB.net. I have no prior experience with VB so I am going through the Solid Edge's Programming help booklet that accompanies the software but I'm running into an issue. Here is my Code:
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim objApp As SolidEdgeFramework.Application = Nothing
        Dim objDocuments As SolidEdgeFramework.Documents = Nothing
        Dim objAssembly As SolidEdgeAssembly.AssemblyDocument = Nothing
        Dim objDraft As SolidEdgeDraft.DraftDocument = Nothing
        Dim objPart As SolidEdgePart.PartDocument = Nothing
        Dim objSheetMetal As SolidEdgePart.SheetmetalDocument = Nothing
        Dim objWeldment As SolidEdgePart.WeldmentDocument = Nothing
        Dim objType As Type
        Try
            'Old VB
            objApp = CreateObject("SolidEdge.Application")
            'New VisualBasic.net Syntax
            objApp = Type.GetTypeFromProgID("SolidEdge.application")
            'Starting Solid Edge
            objApp.Activator.CreateInstance(objType)
            'Make Solid Edge visible
            objApp.Visible = True
            'Turn off Alers (Weldment will display alert)
            objApp.DisplayAlerts = False
            'Get reference to the documents collection
            objDocuments = objApp.Documents
            'Create an instance of each document environment
            objAssembly = objDocuments.Add("SolidEdge.AssemblyDocument")
            objDraft = objDraft.Add("SolidEdge.DraftDocument")
            objPart = objDocuments.Add("SolidEdge.PartDocument")
            objSheetMetal = objDocuments.Add("SolidEdge.SheetmetalDocument")
            objWeldment = objDocuments.Add("SolidEdge.Weldmentdocument")
            'Turn on Alerts
            objApp.DisplayAlerts = True
        Catch ex As Exception
            Console.WriteLine(ex.Message)
        Finally
            If Not (objAssembly Is Nothing) Then
                Marshal.ReleaseComObject(objAssembly)
                objAssembly = Nothing
            End If
            If Not (objDraft Is Nothing) Then
                Marshal.ReleaseComObject(objDraft)
                objDraft = Nothing
            End If
            If Not (objPart Is Nothing) Then
                Marshal.ReleaseComObject(objPart)
                objPart = Nothing
            End If
            If Not (objSheetMetal Is Nothing) Then
                Marshal.ReleaseComObject(objSheetMetal)
                objSheetMetal = Nothing
            End If
            If Not (objWeldment Is Nothing) Then
                Marshal.ReleaseComObject(objWeldment)
                objWeldment = Nothing
            End If
        End Try
    End Sub
End Module
My first question is are those things that I need to define or are they something that should be defined in the SolidEdgeFramework file?
My second is what can I do to fix this?
Patrick Roche
Posted by: Patrick Roche
Post date: 11/23/2008 8:53:35 AM
RE: Beginner Programmer Help
Hi Patrick
Have you added references to the Solid Edge Assembly Type Library, Solid Edge Part Type Library and Solid Edge Geometry Type Library?
If you haven't you should be able to under Project Properties -> References
Posted by: Nick Whitehead
Post date: 11/23/2008 10:18:55 PM
Thank you that resolved the issue.
-Patrick Roche
Post date: 11/26/2008 11:22:28 AM
I have another question. I have gotten my program to open Solid Edge ST, create a part file but it does not seem to draw either the profile or protrude the part. Below is my code. Has anyone else ever experienced this and what was the solution to the problem?
Imports SolidEdgeFramework
Imports SolidEdgeConstants
Module Module1
Private Sub Form_Load()
End Sub
Sub Main()
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
Dim objProfiles As SolidEdgePart.Profiles = Nothing
Dim objProfile As SolidEdgePart.Profile = Nothing
Dim objRefPlanes As SolidEdgePart.RefPlanes = Nothing
Dim objRefPlane As SolidEdgePart.RefPlane = Nothing
Dim objRelations2d As SolidEdgeFrameworkSupport.Relations2d = Nothing
Dim objRelation2d As SolidEdgeFrameworkSupport.Relation2d = Nothing
Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
Dim objLine2d As SolidEdgeFrameworkSupport.Line2d = Nothing
Dim objModels As SolidEdgePart.Models = Nothing
Dim ObjModel As SolidEdgePart.Model = Nothing
Dim objDimensions As SolidEdgeFrameworkSupport.Dimensions = Nothing
Dim objDimension As SolidEdgeFrameworkSupport.Dimension = Nothing
Dim objDimStyle As SolidEdgeFrameworkSupport.DimStyle = Nothing
Dim aProfiles As Array
Dim objType As Type
Try
'Old VB
objApp = CreateObject("SolidEdge.application")
objType = Type.GetTypeFromProgID("SolidEdge.application")
'Turn off Alerts (Weldment will display alert)
'Create Part
'Turn on Alerts
Finally
objPart = Nothing
End If
End Try
'Take a quick break to make sure everything is up to speed
Try
'Connect to SolidEdge. Activated earlier in program.
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
'Get Collection of Documents
objDocuments = objApplication.Documents
'Create new Part
objPart = objApplication.Add("SolidEdge.PartDocument")
'Reference profile sets collection
objProfileSets = objPart.ProfileSets
'Add new profile
objProfileSet = objprofileSets.Add()
'Get reference to profiles
objProfiles = objProfileSet.Profiles
'Ref Reference Planes
objRefPlanes = objPart.RefPlanes
'Add new Profile
objProfile = objProfileSet.Profiles
'Reference lines2d
objLines2d = objProfile.Lines2d
'This is where we start defining our geometry
'Draw Profile
objLine2d = objLines2d.AddBy2Points(0, 0, 0, 1)
objLine2d = objLines2d.AddBy2Points(0, 1, 0.125, 1)
objLine2d = objLines2d.AddBy2Points(0.125, 1, 0.125, 0.125)
objLine2d = objLines2d.AddBy2Points(0.125, 0.125, 1, 0.125)
objLine2d = objLines2d.AddBy2Points(1, 0.125, 1, 0)
objLine2d = objLines2d.AddBy2Points(1, 0, 0, 0)
'Connect Lines together via relationships
objRelation2d = objProfile.Relation2d
objRelation2d = objRelation2d.AddKeypoint(objLines2d.Item(1), KeypointIndexConstants.igLineEnd, objLines2d.Item(2), KeypointIndexConstants.igLineStart)
objRelation2d = objRelation2d.AddKeypoint(objLines2d.Item(2), KeypointIndexConstants.igLineEnd, objLines2d.Item(3), KeypointIndexConstants.igLineStart)
objRelation2d = objRelation2d.AddKeypoint(objLines2d.Item(3), KeypointIndexConstants.igLineEnd, objLines2d.Item(4), KeypointIndexConstants.igLineStart)
objRelation2d = objRelation2d.AddKeypoint(objLines2d.Item(4), KeypointIndexConstants.igLineEnd, objLines2d.Item(5), KeypointIndexConstants.igLineStart)
objRelation2d = objRelation2d.AddKeypoint(objLines2d.Item(5), KeypointIndexConstants.igLineEnd, objLines2d.Item(6), KeypointIndexConstants.igLineStart)
objRelation2d = objRelation2d.AddKeypoint(objLines2d.Item(6), KeypointIndexConstants.igLineEnd, objLines2d.Item(1), KeypointIndexConstants.igLineStart)
'Close Profile
objProfile.End(SolidEdgePart.ProfileValidationType.igProfileClosed)
'Hide Profile
objProfile.Visible = True
'Create an array of profile objects
aProfiles = Array.CreateInstance(GetType(SolidEdgePart.Profile), 1)
aProfiles.SetValue(objProfile, 0)
'Reference to model
ObjModel = objPart.Models
'Protrude
ObjModel = objModels.AddFiniteExtrudedProtrusion(aProfiles.Length, aProfiles, SolidEdgePart.FeaturePropertyConstants.igRight, 6)
Finally
If Not (ObjModel Is Nothing) Then
Marshal.ReleaseComObject(ObjModel)
ObjModel = Nothing
End If
If Not (objModels Is Nothing) Then
Marshal.ReleaseComObject(objModels)
objModels = Nothing
End If
If Not (objRelations2d Is Nothing) Then
Marshal.ReleaseComObject(objRelations2d)
objRelations2d = Nothing
End If
If Not (objLine2d Is Nothing) Then
Marshal.ReleaseComObject(objLine2d)
objLine2d = Nothing
End If
If Not (objLines2d Is Nothing) Then
Marshal.ReleaseComObject(objLines2d)
objLines2d = Nothing
End If
If Not (objRelation2d Is Nothing) Then
Marshal.ReleaseComObject(objRelation2d)
objRelation2d = Nothing
End If
If Not (objRefPlanes Is Nothing) Then
Marshal.ReleaseComObject(objRefPlanes)
objRefPlanes = Nothing
End If
If Not (objProfile Is Nothing) Then
Marshal.ReleaseComObject(objProfile)
objProfile = Nothing
End If
If Not (objProfiles Is Nothing) Then
Marshal.ReleaseComObject(objProfiles)
objProfiles = Nothing
End If
If Not (objProfileSet Is Nothing) Then
Marshal.ReleaseComObject(objProfileSet)
objProfileSet = Nothing
End If
If Not (objProfileSets Is Nothing) Then
Marshal.ReleaseComObject(objProfileSets)
objProfileSets = Nothing
End If
objPart = Nothing
End If
If Not (objDocuments Is Nothing) Then
Marshal.ReleaseComObject(objDocuments)
objDocuments = Nothing
End If
If Not (objApplication Is Nothing) Then
Marshal.ReleaseComObject(objApplication)
objApplication = Nothing
End If
End Try
Console.Write("Press Enter to Continue")
Console.ReadLine()
End Sub
End Module
Post date: 12/1/2008 3:33:49 PM
