BindKeyToObject() c++ usage
Hi everyone.
Anyone knows why BindKeyToObject() works fine for Part files, but not for Assembly files?
I have the following code
SAFEARRAY *pRefKey = 0;
IDispatchPtr ids = 0;
pFace->GetReferenceKey(&pRefKey ); //pFace is a valid face. this line works
doc->BindKeyToObject(&pRefKey, &ids); // valid .par or .asm document.
this code works ok for Part document. But not for Assembly document
Anyone knows whay i'm doing wrong?
Thank you
Re: BindKeyToObject() c++ usage
I did a fast test on ST7 and can confirm your problem, although I was testing edges. It seems, that topologies are not supported in Assembly, as an E_INVALIDARG exception is thrown.
You file an IR on that issue.
