Block Occurrences
Hi
I need unblock all of the blocks in DFT.
I use
For Each objSheet In objDraft.Sections.WorkingSection.Sheets
    With objSheet
        For i = .BlockOccurrences.Count To 1 Step -1
            .BlockOccurrences(i).Unblock
        Next
   end with
Same for Background Sheets but I don't know,  how I can unblock used block occurrences in user defined 2D Views?
Can anyone help me?
Posted by: Dalibor Sidlo
Post date: 7/28/2009 2:49:35 AM
RE: Block Occurrences
You almost got it...
For Each objSheet In objDraft.Sheets 'This will search all sheets (working and background)
With objSheet
.BlockOccurrences(i).Unblock()
Next
'In every sheet look for drawing views and unblock blocks
For Each objDrawingView In .DrawingViews
For i = objDrawingView.Sheet.BlockOccurrences.Count To 1 Step -1
objDrawingView.Sheet.BlockOccurrences.item(i).Unblock()
Next
Next
End With
Next
Posted by: Julian Guillo
Post date: 7/28/2009 3:10:28 AM
