Broken Interpart Links
Hello!
I am iterating through a documents interpart links and I need to find out if a link is broken.
Currently, I only see the property "IsFrozen" but there is no "IsBroken"
Any help would be greatly appreciated!
Thanks!
Public Function GetInterpartLinks() As List(Of String)
Dim interparts As New List(Of String)
Try
Dim objInterPartLinks As SolidEdgeFramework.InterpartLinks = Document.OccurrenceDocument.InterpartLinks
Dim sourceFeatureName As String = ""
Dim documentName As String = ""
Dim objInterPart As SolidEdgeFramework.InterpartLink
For i = 1 To objInterPartLinks.Count
objInterPart = objInterPartLinks.Item(i)
objInterPart.GetInfo(sourceFeatureName, documentName)
If documentName.Trim.Count = 0 Then Continue For
interparts.Add(documentName)
Next
Catch ex As Exception
Debug.Print(ex.Message)
End Try
interparts = interparts.Distinct.ToList
Return interparts
End Function
Posted by: maury terneus
Post date: 7/3/2013 7:50:53 AM
Maury,
lacking the property IsBroken in an InterPartLink object you may define a InterPartLink broken, if either the document returned by GetInfo doesn't exist or the Feature returned by GetInfo doesn't exist in the document returned.
Posted by: Wolfgang Kunert
Post date: 7/3/2013 11:13:07 AM
