C++: Dim & Var in variableList
In my assembly I have a reference plane at a distance to another reference plane. This distance is listed in the variableList, but neither casting it to variablePtr nor to DimensionPtr leads to a pointer != 0.
What other type do I have to check against?
And how could I access the value?
Thank you!
Posted by: Bodo Quaschnowitz
Post date: 1/10/2013 8:54:55 AM
3 REPLIES 3
Unfortunately is this a SolidEdgeAssembly::AsmRefPlane and not variable or dimension in the variableList.
I don't know how to get or set the distance for the plane.
Posted by: JR
Post date: 1/11/2013 6:57:37 AM
See if the object has a .GetTransform() and PutTransform()
Posted by: Terry Tyson
Post date: 1/18/2013 10:23:48 AM
Bodo,
GetRootPoint returns the coordinates of the center of the RefPlane.
Gerald
Posted by: Gerald Haberl
Post date: 1/21/2013 6:12:59 AM
