C# : How to begin ?
Hi Jason,
I have to write an interface between SolidEdge and SAP R3. First of all, I will need to control basic stuffs in SE17/18(ex: custom properties).
I made some things in vb6, but I thought that switching to .NET should be a good solution, and I chose C# (I am working with c# Express 2005)
In order to understand how I can program in C#, could you please write me some very basic examples, or tell where could I find info about C#/SEdge ?
For exemple :
- Run SEdge if it's off with the error gestion if it's running
Like in VB:
Set objAplicacion = GetObject(, "SolidEdge.Application")
If Err Then
Err.Clear
Set objAplicacion = CreateObject("SolidEdge.Application")
End If
On Error GoTo 0
objAplicacion.Visible = True
Set objDocumentos = objAplicacion.Documents
Set objFso = CreateObject("Scripting.FileSystemObject")
- Access to a property (or custom prop) and change it
I will share my SAP application when finished, because I read that some people is interested in SAP R3 connection.
Could you please send me the test you did with SAP ?
Thanks a lot, as you see, I m a C# AND SE beginner, so I really need your help !!
Posted by: Greg Forel
Post date: 4/4/2006 2:55:58 AM
RE: C# : How to begin ?
By the way, sorry for my English, I m French and I m working in Argentina, so...
Post date: 4/4/2006 2:57:18 AM
