C# RevisionManager.Document problem
VB6 code works fine
Private Sub Command1_Click()
Dim rm               As Object
Dim doc              As Object
Dim links            As Object
Dim n                As Integer
Set rm = GetObject("", "RevisionManager.Application")
Set doc = rm.Open("D:\test.asm")
Set links = doc.LinkedDocuments
n = links.Count
End Sub
C# code doesn't work.
Revision Manager object is created perfectly, but instead of opened document null reference is coming. Any ideas ???
        private void button2_Click(object sender, EventArgs e)
            RevisionManager.ApplicationClass rm = new RevisionManager.ApplicationClass(); // very good object !!!
            object RevisionRuleOption = RevisionManager.RevisionRuleType.LatestRevision;
            object StopFileOpenIfRevisionRuleNotApplicable = new object(); // what should be here ???
            object odoc = rm.Open("D:\\test.asm",
                                  StopFileOpenIfRevisionRuleNotApplicable); // null reference , why ???
            RevisionManager.Document doc = (RevisionManager.Document)odoc;
            object oLinkedDocs = doc.get_LinkedDocuments(null);  // Null Reference exception will be Smiley Sad
Posted by: George Sarty
Post date: 5/12/2008 3:55:05 AM
RE: C# RevisionManager.Document problem
using System;using System.Runtime.InteropServices;namespace RevisionManager{ class Program { static void Main(string[] args) { RevisionManager.Application application = null; RevisionManager.Document document = null; RevisionManager.LinkedDocuments linkedDocuments = null; RevisionManager.Document linkedDocument = null; try { application = new RevisionManager.Application(); document = (RevisionManager.Document) application.Open(@"C:\Asm1.asm", RevisionRuleType.LatestRevision, false); linkedDocuments = (RevisionManager.LinkedDocuments) document.get_LinkedDocuments(RevisionManager.LinkTypeConstants.seLinkTypeAll); for (int i = 1; i
Posted by: Jason Newell
Post date: 5/14/2008 9:44:20 PM
Thank you very much, Jason.
we found before your answer i.e. 13/05/2008 that we must pass bool value to make Open() working,
but today I've grabed finally {...} block from you code, just killed unnecessarry assignments = null to local variables as they are not needed.
So, you answer was useful
/// Usage example:
/// SolidEdgeManager m = SolidEdgeManager.Instance;
/// Assembly asm = new Assembly();
/// m.CreateAllChildren(asm);
/// Special thanks to Jason Newell for finally block, see my question at
/// we found that "stopFileOpenIfRevisionRuleNotApplicable" should be of bool type by ourselves
/// one day before Jason's advise, i.e. 14/05/2008, anyway thanks once again
public List CreateAllChildren(Entity entity)
FactoryManager fm = FactoryManager.Instance;
List links = new List();
tm.Log(TraceCategory.Debug, string.Format("SolidEdge revision manager extracts links from [{0}]", entity.FileName));
// create revision manager
application = new Application();
RevisionRuleType revisionRuleOption = RevisionRuleType.LatestRevision;
bool stopFileOpenIfRevisionRuleNotApplicable = true;
document = (Document) application.Open(entity.FileName, revisionRuleOption, stopFileOpenIfRevisionRuleNotApplicable);
// get children collection
LinkTypeConstants linkTypeOption = LinkTypeConstants.seLinkTypeAll;
linkedDocuments = (LinkedDocuments) document.get_LinkedDocuments(linkTypeOption);
for (int i = 1; i
linkedDocument = (Document) linkedDocuments.get_Item(i);
// we are working with entities instead of file names
Entity childEntity = fm.CreateEntityByFileName(linkedDocument.FullName);
// clean unmanaged COM resources
if (linkedDocument != null)
if (linkedDocuments != null)
if (document != null)
if (application != null)
return links;
Posted by: lucky1 lucky1
Post date: 6/12/2008 2:25:11 AM
some troubles with tabulations, oops.
By the way what's the difference when
stopFileOpenIfRevisionRuleNotApplicable = false
Post date: 6/12/2008 2:28:24 AM
I have one more question.
I have just opened big Assembly, and one link to sub-assembly has strange suffix [!OPEN]
where can I have a list of all possible suffixes ???
I'm expecting full file name path, so my program raise an exception Smiley Sad
May I just remove suffix and treat it like sub-assembly?
Any underwater stones?
Post date: 6/12/2008 3:07:04 AM
