C# SE AddIn Save as flat
I would like when the SE User press Save as flat.
That my AddIn writes a fixe save address and file name to the window. Than the user only have to check it and press save.
I hope somebody can help me that I see it in my Program, when somebody press “save as flat “ and then it file the file name in the box. I tried it with public void BeforeDocumentSave(object theDocument) but this is only fort the normal save button. Is there a different command for the “save as flat” button?
Thanks for your help
