C++ Solid Edge intro
Is there a document or post somewhere that explains the basics of accessing Solid Edge using C++. I'm currently using VB.NET and in the process of learning C++ and I need a push start in how to access Solid Edge with C++.
Terry
Posted by: Terry Tyson
Post date: 6/17/2011 3:56:08 AM
3 REPLIES 3
RE: C++ Solid Edge intro
Terry,
Check out the Community Contributions forum. Specifically, see the Solid Edge API Demos (C++) post.
Posted by: Jason Newell
Post date: 6/19/2011 2:46:26 PM
Thanks Jason.
Post date: 6/22/2011 3:24:12 AM
In stdafx.h on the line
#import "libid:42E04299-18A0-11D5-BBB2-00C04F79BEA5"
I get the following error:
Error: cannot open source file "C:/Users/ttyson/Downloads/SolidEdgeApiDemo_CPP/SolidEdgeApiDemo/Debug/libid:42E04299-18A0-11D5-BBB2-00C04F79BEA5.tlh
The same for all the other #import lines. How can I resolve this?
I'm using VS2010 and ST2 on Win7.
Post date: 7/12/2011 9:48:14 AM
