C++: delete feature from part
Hi colleagues,
Does anyone knows C++ code that deletes a feature (identified by IDispatchPtr) from a part file?
Thank you,
Bodo
Re: C++: delete feature from part
Here is the code:
HRESULT DeleteFeature(IDispatchPtr pFeature)
  if (pFeature == NULL) return E_POINTER;
  HRESULT  hr = S_OK;
  DISPID   dispId;
  LPOLESTR names[1] = { L"Delete" };
  hr = pFeature->GetIDsOfNames(IID_NULL, names, 1, LOCALE_USER_DEFAULT, &dispId);
  if (SUCCEEDED(hr))
    try
      hr = _com_dispatch_method(pFeature, dispId, DISPATCH_METHOD, VT_EMPTY, NULL, NULL);
    catch (_com_error &e)
      hr = e.Error();
  return hr;
Works at once like a charm!
Thank's a lot!
