C# equivalent of code
Hello ,
there's a piece of code from the Solid Edge ST .Net Programmers Guide that I'm trying to implement in C# but without success; There seems to somethings missing in C# versus in
The code is on page 88 of that document (see below);
In particular I cannot determine the type of a Relation3d object in C#, which is easily and directly accessible in (i.e. objRelation3d.Type)
I've try to use the C# Object .GetType() method and all sorts of different approaches but none of them worked. Finally, I compiled the offending piece in and used it in C#;
Any idea how to implement the equivalent of objRelation3d.Type in C#?
--------- Code  --------
objAssembly = objApplication.ActiveDocument
' Get a reference to the relations 3d collection
objRelations3d = objAssembly.Relations3d ' Loop through the relations 3d objects
 ForEach objRelation3d In objRelations3d ' Determine the relation type
objAngularRelation3d = objRelation3d
objAxialRelation3d = objRelation3d
objGroundRelation3d = objRelation3d
objPointRelation3d = objRelation3d
objPlanarRelation3d = objRelation3d
 SelectCase objRelation3d.TypeCase SolidEdgeFramework.ObjectType.igAngularRelation3dCase SolidEdgeFramework.ObjectType.igAxialRelation3dCase SolidEdgeFramework.ObjectType.igGroundRelation3dCase SolidEdgeFramework.ObjectType.igPointRelation3dCase SolidEdgeFramework.ObjectType.igPlanarRelation3dEndSelect
Posted by: Chahe Adourian
Post date: 9/16/2008 1:43:59 PM
RE: C# equivalent of code
VB does a lot of "stuff" for you.  C# is a little more work.
 SolidEdgeAssembly.Relations3d relations3d = assemblyDocument.Relations3d;for (int i = 1; i
Posted by: Jason Newell
Post date: 9/17/2008 7:30:10 AM
Thanks Jason.
Post date: 9/18/2008 12:40:56 PM
