Calculating location of text on dimension objects
This question is similar to what was brought up by this post regarding balloon text:
http://www.jasonnewell.net/Forums/tabid/55/view/topic/forumid/1/postid/2176/ptarget/2176/Default.asp...
I'd like to be able to figure out where the text component of a dimension is located so I can key off that location in adding some additional graphic objects near the dimension text.
Does anyone know of a trick to doing this? The range method for the dimension object gives max/min points only.
Mark
Posted by: Mark Nalevanko
Post date: 7/3/2009 10:48:59 AM
RE: Calculating location of text on dimension objects
Well, after a little more digging I've answered my own question using the GetDisplayData() method on the dimension object and then retrieving text location info via GetTextCount() and GetTextAtIndex() methods on the DisplayData object.
Post date: 7/3/2009 11:06:51 AM
