Can't change TextBox.VerticalAlignment in V19.00.11.03 - API problem or program problem ?
what's the matter, trying to change the horizontal and vertical alignment of the textbox, but only horizontal is working...!!
With old Version 19, anyone knows if its working with newer se version... or is there a mistake in coding...what does justification do
'SetUp Style
TextBox.Edit.TextSize = 2.5 / 1000
TextBox.Edit.HorizontalAlignment = = SolidEdgeFrameworkSupport.TextHorizontalAlignmentConstants.igTextHzAlignCenter
TextBox.VerticalAlignment = SolidEdgeFrameworkSupport.TextVerticalAlignmentConstants.igTextHzAlignVCenter
TextBox.Justification = SolidEdgeFrameworkSupport.TextJustificationConstants.igTextJustifyVCenter
Posted by: Linus Hechinger
Post date: 5/2/2010 9:58:33 PM
