Can't find Property for dft-view flattened !
Is there no property for a drawing view, modelnode, part...
whatever from inside the draft
where I can get back any information about
the view is a flattened psm or the "normal" modelview....?
I'm writing a custom text to the view.CaptionDefinitionTextPrimary
(sapbom number and material thickness) and I'd like
to also add some words to the view, if it's a flattened view,
am I blind - maybe: feeling a bit ill today Smiley Surprisedops:
Posted by: Linus Hechinger
Post date: 1/29/2013 6:39:37 AM
Hi Linus,
the property DrawingView.ViewType could return what you are searching for:
[i]ViewType Property
Solid Edge Draft Type Library > DrawingView Object : ViewType Property
Description
Returns an integer to indicate the model options on the DV: 0 = Design body, 1 = Simplified body, 2 = Flat sheet metal or Simplified by config.
Property type
Read-only property[/i]
Posted by: Wolfgang Kunert
Post date: 1/30/2013 5:51:36 AM
[url=http://www.jasonnewell.net/products/solid-edge-spy.html]Solid Edge Spy[/url] to the rescue!
[attachment=190]SESpy_5266.png[/attachment]
Posted by: Jason Newell
Post date: 2/5/2013 2:36:01 AM
