Can't make lines with visual basic.net
I made an console application to make curves and line in Solid Edge with the methods Bsplinecurve2d and lines2d. I use data from a text file to make the curves. The problem is no line is drawn and i don't get whu, because visual basic isn't ging any errors. And the data does get calculated and stored into arrays.
Maybe the probelm is that i'm using visul basic 2003 with Solid Edge ST2?
Can some give a look at my code?
Thanks in advance.
[code type=vbnet]Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Collections
Module Module1
Sub Main()
Dim strFileName As String = "U:\pompen.prn"
Dim objFS As New FileStream(strFileName, FileMode.Open, FileAccess.Read)
Dim objSR As New StreamReader(objFS)
Dim objApp As SolidEdgeFramework.Application = Nothing
Dim objDocuments As SolidEdgeFramework.Documents = Nothing
Dim objPart As SolidEdgePart.PartDocument = Nothing
Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
Dim objProfiles As SolidEdgePart.Profiles = Nothing
Dim objProfile As SolidEdgePart.Profile = Nothing
Dim objRefplanes As SolidEdgePart.RefPlanes = Nothing
Dim objBspline As SolidEdgeFrameworkSupport.BSplineCurve2d = Nothing
Dim objBsplines As SolidEdgeFrameworkSupport.BSplineCurves2d = Nothing
Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
Dim objLine2d As SolidEdgeFrameworkSupport.Line2d = Nothing
Dim strEmpRecord As String
Dim type As String
Dim N1 As Double
Dim QT As Double
Dim DW1 As Double
Dim EQ As Double
Dim EH As Double
Dim DWL As Double
Dim DHL As Double
Dim C1 As Double
Dim C2 As Double
Dim C3 As Double
Dim C4 As Double
Dim C5 As Double
Dim QFACTOR As Double
Dim q As Double
Dim h As Double
Dim qx As Double
Dim hx As Double
Dim qa As Double
Dim ha As Double
Dim qeind As Double
Dim qeind2 As Double
Try
'connect to a Solid Edge file.
'Connect to a running instance of Solid Edge
objApp = Marshal.GetActiveObject("SolidEdge.Application")
'Get a reference to the documents collection
objDocuments = objApp.Documents
'Create a new part document
objPart = objDocuments.Add("SolidEdge.PartDocument")
'Get a reference to the profile sets collection
objProfileSets = objPart.ProfileSets
'Add a new profile set
objProfileSet = objProfileSets.Add()
'Get a reference to the profiles collection
objProfiles = objProfileSet.Profiles
'Get a reference to the ref planes collection
objRefplanes = objPart.RefPlanes
'Add a new profile
objProfile = objProfiles.Add(objRefplanes.Item(3))
'Get a reference to spline curve collection
objBsplines = objProfile.BSplineCurves2d
'Get a reference to the lines2d collection
objLines2d = objProfile.Lines2d
Dim nfi As Globalization.NumberFormatInfo = New Globalization.CultureInfo("en-US", False).NumberFormat
nfi.NumberGroupSeparator = " "
nfi.NumberDecimalSeparator = ","
Do While objSR.Peek <> -1
' read the current record (line) into the variable strEmpRecord
strEmpRecord = objSR.ReadLine
Try
' break up the record into separate variables
type = strEmpRecord.Substring(1, 19)
N1 = CDbl(strEmpRecord.Substring(20, 9))
QT = CDbl(strEmpRecord.Substring(30, 9))
DW1 = CDbl(strEmpRecord.Substring(40, 9))
EQ = CDbl(strEmpRecord.Substring(50, 9))
EH = CDbl(strEmpRecord.Substring(60, 9))
DHL = CDbl(strEmpRecord.Substring(70, 9))
DWL = CDbl(strEmpRecord.Substring(80, 9))
C1 = CDbl(strEmpRecord.Substring(90, 19))
C2 = CDbl(strEmpRecord.Substring(110, 19))
C3 = CDbl(strEmpRecord.Substring(130, 19))
C4 = CDbl(strEmpRecord.Substring(150, 19))
C5 = CDbl(strEmpRecord.Substring(170, 19))
QFACTOR = CDbl(strEmpRecord.Substring(190, 3))
Catch ex As System.InvalidCastException
End Try
Loop
'Dmax
Dim i As Double
Dim listofdata As New ArrayList
For i = 0.2 To QFACTOR Step 0.1
q = (i * QT)
h = (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5)
listofdata.Add(q)
listofdata.Add(h)
Next
Dim dataArray() As Double
dataArray = DirectCast(listofdata.ToArray(GetType(Double)), Double())
'Dmin
qx = ((DWL / DW1) ^ EQ)
hx = ((DWL / DW1) ^ EH)
Dim listofdata2 As New ArrayList
For i = 0.2 To 1.5 Step 0.1
q = (i * QT)
qa = (qx * q)
ha = (hx * (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5))
listofdata2.Add(qa)
listofdata2.Add(ha)
Next
Dim data2Array() As Double
data2Array = DirectCast(listofdata2.ToArray(GetType(Double)), Double())
'make connection lines
qeind = (QFACTOR * QT)
qeind2 = (qx * qeind)
objLine2d = objLines2d.AddBy2Points(qeind2, (hx * (((qeind2 ^ 4) * C1) + ((qeind2 ^ 3) * C2) + ((qeind2 ^ 2) * C3) + (qeind2 * C4) + C5)), qeind, (((qeind ^ 4) * C1) + ((qeind ^ 3) * C2) + ((qeind ^ 2) * C3) + (qeind * C4) + C5))
objBspline = objBsplines.AddByPoints(2, 13, dataArray)
objBspline = objBsplines.AddByPoints(2, 14, data2Array)
' Close the profile
objProfile.End( _
SolidEdgePart.ProfileValidationType.igProfileClosed)
Finally
If Not (objLine2d Is Nothing) Then
Marshal.ReleaseComObject(objLine2d)
objLine2d = Nothing
End If
If Not (objLines2d Is Nothing) Then
Marshal.ReleaseComObject(objLines2d)
objLines2d = Nothing
End If
If Not (objBspline Is Nothing) Then
Marshal.ReleaseComObject(objBspline)
objBspline = Nothing
End If
If Not (objBsplines Is Nothing) Then
Marshal.ReleaseComObject(objBsplines)
objBsplines = Nothing
End If
If Not (objRefplanes Is Nothing) Then
Marshal.ReleaseComObject(objRefplanes)
objRefplanes = Nothing
End If
If Not (objProfile Is Nothing) Then
Marshal.ReleaseComObject(objProfile)
objProfile = Nothing
End If
If Not (objProfiles Is Nothing) Then
Marshal.ReleaseComObject(objProfiles)
objProfiles = Nothing
End If
If Not (objProfileSet Is Nothing) Then
Marshal.ReleaseComObject(objProfileSet)
objProfileSet = Nothing
End If
If Not (objProfileSets Is Nothing) Then
Marshal.ReleaseComObject(objProfileSets)
objProfileSets = Nothing
End If
If Not (objPart Is Nothing) Then
Marshal.ReleaseComObject(objPart)
objPart = Nothing
End If
If Not (objDocuments Is Nothing) Then
Marshal.ReleaseComObject(objDocuments)
objDocuments = Nothing
End If
If Not (objApp Is Nothing) Then
Marshal.ReleaseComObject(objApp)
objApp = Nothing
End If
End Try
objSR.Close()
Console.WriteLine("")
Console.WriteLine("Press Enter to close this window.")
Console.ReadLine()
End Sub
End Module
[/code]
Posted by: Andries
Post date: 11/21/2012 8:16:38 AM
Okay i managed to make it draw my lines and curves, but the problem now is that my data is stored as meters. In solid eddge i will get really big lines and curves. Can i convert my data in visual basic to millimeters?
Also i wnat to edit my sketch, but i cant acces my sketch. And when i save th file, the lines and curves just disappear.
Posted by: Andries
Post date: 11/22/2012 4:01:58 AM
SE works in meters internally. This will help going back and forth from meters to inches.
[code type=vbnet]
Public Const m_to_in = 39.3700787402
var.Value = varValue / m_to_in ' From app to SE.
varValue = var.Value * m_to_in ' From SE to app.
[/code]
Posted by: Terry Tyson
Post date: 12/4/2012 8:16:46 AM
