Can't open file wiht File Property API
Hi Jasson,
i have a problem with your create Projekt Solid Edge File Property API (.NET).
If i use your example than i recive an error (see attechment)
But if i use another part than is all ok.
Sorry, my english si very bad.
Marco Kreutz
info@hittem.de
www.hitteam.de
Posted by: Marco Kreutz
Post date: 2/5/2006 8:52:00 PM
RE: Can't open file wiht File Property API
Marco,
If you'll reply and attach the file, I can quickly debug the issue.
Thanks.
Posted by: Jason Newell
Post date: 2/6/2006 9:44:33 AM
Hi Jasson,
her is the problem part...
Post date: 2/6/2006 10:26:50 PM
Sorry Marco but I don't see an attachment. You might try again. You can always email admin@jasonnewell.net also.
Post date: 2/7/2006 1:43:24 AM
