Can you help me???
I did hide a SolidEdge Application...
Maybe "seApp.Visible = False" this code...
So I completion change to .par from .igs...
But survive the afterimage and progress
I will add file...
So can you give me a suggestion...
help me...
Posted by: gmpark
Post date: 10/17/2012 9:58:35 PM
Can you help me???
hi,
I didn't fully understood what you wanted to do.
If you would like to hide the solid app than:
application.Visible = false; //this is from my C# in VB it will be the same. make sure application is initialize.
If that didn't answer what you wanted - Please explain yourself with complete sentences.
When one reads what you wrote I can't understand what you requested..
Posted by: joseph polk
Post date: 10/18/2012 6:00:51 AM
Can you help me???
Hello gmpark,
both graphics effects unfortunately can't be suppressed as far as i know, even if SolidEdgeApplication.visible is set to false Smiley Sad
Posted by: Wolfgang Kunert
Post date: 10/18/2012 11:10:06 AM
Can you help me???
For the first one try:
[code type=vbnet]seApp.DisplayAlerts = False[/code]
For the second one try:
In Options/Helpers
Un-select "Show Pathfinder in the document view"
HTH
Posted by: Terry Tyson
Post date: 10/19/2012 9:19:46 AM
