Can you use DoIdle() too much?
Can you use DoIdle() too much? For instance, if you have it in a function, and someone calls that function from a loop, would that be too much. I know that you shouldn't call Update() and Save() inside a loop because that would slow things down quite a bit but was wondering if DoIdle() had the same kind of overhead.
Terry Tyson
Software Automation Designer
Re: Can you use DoIdle() too much?
I would say that it depends on the scenario and code. If you just wrote a tight loop calling DoIdle(), then yes, I'd say that's bad. If you were processing a lot of documents and calling calling DoIdle() after Document.Close(), then I would say no, that's not a bad.
Breadcrumb for those reading this years later: See DoIdle() documentation for more details.
Jason Newell
Applications Architect
www.jasonnewell.net
Ah, I see. That makes sense. Thanks Jason.
Terry Tyson
