Capital letters in automated custom property creation
I have a bas file that I use to create a custom property based on a variable value that I pass to the model from an Excel sheet.  I then take the custom property and call it out as property text on my draft file.  My question is: currently no matter how it is formatted in the bas file, the text always comes out as all lowercase.  Is there a way to change that so it creates it in all capitals?
Posted by: Daron Callahan
Post date: 12/12/2007 9:42:33 AM
RE: Capital letters in automated custom property creation
Is the proeperty lower case when you view it inside of Solid Edge? When you write the property to the file, you have total control over the case. I believe in VB6 the command was UCASE() or something like that.
Posted by: Jason Newell
Post date: 12/16/2007 9:11:12 PM
Thanks,  Yes I was able to use the UCASE command to get it to work.
Thanks for a great site.
Post date: 12/17/2007 5:51:37 AM
