CatID for synchronous Part/Assembly
Hallo I have an addin for SE v20 and want to load it in SE ST.
If it is loaded in SE ST I don't have my menus for synchronus part and synchronous assembly.
I have defined one menu for one Catid (for the following catids):
 ' Part
    CATID_SEPart = "{26618396-09D6-11d1-BA07-080036230602}"
  ' Assembly
    CATID_SEAssembly = "{26618395-09D6-11d1-BA07-080036230602}"
But when I open a "Synchronus ISO Part" or "Synchronus ISO Assembly" I don't have any menus of my addin.
which catid do I have to use for "Synchronus ISO Part" and "Synchronus ISO Assembly"?
I can't find it in "secatids.h"
soth
Posted by: marcus heimsoth
Post date: 11/18/2008 11:06:33 PM
RE: CatID for synchronous Part/Assembly
i just found it:
Select Case EnvCatID.ToLower
'Part
Case "{26618396-09D6-11d1-BA07-080036230602}".ToLower
'Synchronous Part
Case "{D9B0BB85-3A6C-4086-A0BB-88A1AAD57A58}".ToLower
'Assembly
Case "{26618395-09D6-11D1-BA07-080036230602}".ToLower
'Synchronous Assembly
Case "{2C3C2A72-3A4A-471D-98B5-E3A8CFA4A2BF}".ToLower
End Select
Post date: 11/19/2008 2:13:34 AM
