Change Aktive Window in SE with VB.Net
has someone an idea how to switch between to dokuments e.g. x1.dft and x2.dft via VB.NET.
The SolidEdge Spy gives the commands AfterActiveDocumentChange and AfterWindowActivate)
But I find no equivalent in the documentation.
Thank you in advance.
4 REPLIES 4
Re: Change Aktive Window in SE with VB.Net
simply use the method Activate of your document variable of type DraftDocument or SolidEdgeDocument.
Kind regards,
Wolfgang Kunert - www.wksyspro.de
just use the method Activate of your document variable.
Kind regards,
Thx
With objApp.Documents.Item(2) the IDE didn't show the method "Activate".
With
objDraft = objApp.Documents.Item(2)
objDraft.Activate()
"Activate" was directly shown.Smiley Happy
without using a document variable directly, casting would have helped.
CType(objApp.Documents.Item(2), SolidEdgeFramework.SolidEdgeDocument).Activate
Kind regards,
