Change Drafting background color
HI,
i need to change the background color of a drawing from black to white
from visual basic.
Thanks in advance for any help.
Best Regards
MAssimo
Posted by: Massimo Magris
Post date: 9/21/2007 10:25:31 PM
RE: Change Drafting background color
Massimo,
How do you set the Draft background color inside Solid Edge? The only way I can see to do it is to use the "Fill" command on a given background sheet. Your answer will help me find you a solution.
Posted by: Jason Newell
Post date: 9/25/2007 7:43:06 AM
To change the background color, you need to change the "Sheet" color via Tools ==> Options ==> Colors
Posted by: Bill Ledbetter
Post date: 9/26/2007 6:49:14 AM
