Change Font Size of Text Box
Hi Guys, hope someone can help with this simple task
i have searched the forum but not found an answer.
i have copied and butchered someone else's code to produce what i have shown below,
The idea is to check and correct all text on a drawing to make sure its all the same
font, size, style etc.
I have got it working for font, but i cant find a way to set the font height,
i believe it should be
SolidEdgeFrameworkSupport.TextEdit.TextSize
but i cant get it to work, keeps complaining about a Null reference
Another approach would be if i could set all text (textbox and dims) to a defined style
This is the problem part of the code below
Dim
objApp AsSolidEdgeFramework.Application
Dim objDoc AsSolidEdgeDraft.DraftDocument
Dim objSheet AsSolidEdgeDraft.Sheet
Dim objSectionSheets AsSolidEdgeDraft.SectionSheets
Dim objDimStyle AsSolidEdgeFrameworkSupport.DimensionStyle
Dim objDimStyles AsSolidEdgeFrameworkSupport.DimensionStyles
Dim objTextBox AsSolidEdgeFrameworkSupport.TextBox
Dim objTextBoxes AsSolidEdgeFrameworkSupport.TextBoxes
Dim objTextEdit AsSolidEdgeFrameworkSupport.TextEdit
Dim d AsInteger
'Connect to Solid Edge
objApp = Marshal.GetActiveObject(
'Get Reference to active document
objDoc = objApp.ActiveDocument
'This is where i get the problem,
objTextEdit = objDoc.TextEdit   ->   does not list TextEdit
objTextEdit.TextSize = (3)
'Code to gloablly change font in all dimension styles
objDimStyles = objDoc.DimensionStyles
 ForEach objDimStyle In objDimStyles
objDimStyle.Font = "Arial"
Next
Thanks Guys
 "Comic Sans MS""SolidEdge.Application")
Posted by: Paul McGiven
Post date: 8/6/2009 1:17:33 AM
RE: Change Font Size of Text Box
you set objTextEdit = objDoc.TextEdit but TextEdit is a property of TextBox not from objDoc
Try this:
For i = 1 To objDoc.Sheets.Count
 For j = 1 To objDoc.Sheets(i).TextBoxes.Count
  objTextBoxes=objDoc.Sheets(i).TextBoxes
  objTextEdit = objTextBoxes(j).Edit
  objTextEdit.TextSize=3
 Next j
Next i
jr
Posted by: JR
Post date: 8/10/2009 11:46:38 PM
Thanks JR but i still get
Object variable or With block variable not set.
at
Post date: 8/11/2009 3:13:32 AM
Hi Paul,
I forgot that in vb.Net sometimes called "ITEM" is needed (Item is not set to default property).
Try this:
  For j = 1 To objDoc.Sheets.Item(i).TextBoxes.Count
   objTextBoxes = objDoc.Sheets.Item(i).TextBoxes
   objTextEdit = objTextBoxes.Item(j).Edit
   objTextEdit.TextSize = 0.003
  Next j
Next i
If you have groups with TextBoxes on the sheets you must loop the groups too.
JR
Posted by: JR
Post date: 8/11/2009 7:29:48 PM
Thanks JR, but i figured it out, shown below
For d = 1 To Working_Sheets_Per_Drawing
objSheet = objSectionSheets.Item(d)
objSheet.Activate()
objTextBoxes = objSheet.TextBoxes()
For Each objTextBox In objTextBoxes
'objTextBox.Edit.Font = "Arial"
objTextBox.Edit.Font = SelFont
objTextBox.Edit.TextSize = FontSize ' 0.005 = 5mm, was (0.005)
Next
Next
this works a treat on textboxes, now trying to get it to work on dimension text
the following works on the dim text font
For Each objDimStyle In objDimStyles
objDimStyle.Font = SelFont
'Need to change dimension text size
Next
Just need now to change the dimension text font size.
When i started this small program i did not think it would be such a problem,
to be honest you would think SE would have a built in function to allow you to
set all text on a drawing to the same font / size.
Post date: 8/12/2009 10:39:18 PM
I don't know the Funktion to change the font of all TexBoxes.
For DimStyles use objDimStyle.Height to change the font size.
After the Loop you must refresh the view, for example with:
objDoc.UpdatePropertyTextCacheAndDisplay()
Posted by: JR
Post date: 8/12/2009 11:10:31 PM
