Change Part Face Style in Assembly
 Hi All,
          I want to change part face style in assembly Enviroment, I am Able to do so using the code from Thread
https://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/Changing-the-Part-Color-i...
but in my case i have a very large assembly and this process is taking a lot of time, there is a way manually we can do it a lot faster i am attaching a video showing that . Is that possible using API if possible then please provide example.
(view in My Videos)
Kind Regards
Deepak
Re: Change Part Face Style in Assembly
Please see my suggestions in the other thread...
