Change colors of table lines and hatch lines
Hello People,
I have a button in my macro ( VBA ) Which changes the colors of old drawings to new colors. But I can't get it done with the table lines and hatch lines. By hand the following things need to be done
In a drawing -> Styles -> Table -> Normal_1 -> Modify -> Lines tab -> Colors to black
Or
In a drawing -> Styles -> Hatch -> Normal -> Modify -> Properties -> Pattern Color to black
I've tried the following
Spoiler
  Dim SEtablestyles As SolidEdgeFrameworkSupport.TableStyles
            SEtablestyles = SEDraftDocument.TableStyles
            Dim SEtablestyle As SolidEdgeFrameworkSupport.TableStyle
            Dim SELinecolor = SEtablestyle.LineColor()
            For Each SETablestyle As SolidEdgeFrameworkSupport.TableStyle In SEtablestyles
                linecolor = SETablestyle.LineColor '????????????'
            Next
What is going wrong with the linecolor?
Solid edge Spy says this:
The images are in the alst spoiler
Spoiler
Int32 LineColor(SolidEdgeFrameworkSupport.TableStyleLineTypeConstants#SolidEdgeFrameworkSupport.TableStyleLineTypeConstants lineType) { get; set; }
Member of SolidEdgeFrameworkSupport.TableStyle
Summary:
Line color.
ID:
5 (0x00000005)
Spoiler
Kindly Regards,
Justin
Re: Change colors of table lines and hatch lines
Hi Justin,
for the Table the LineColor is an indexed Property, so try this:
            For Each SEtablestyle In SEtablestyles
                Debug.Print(SEtablestyle.Name)
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seBorder) = &HFFFF
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seTitleSeparator) = &HFF00FF
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seTitleHeaderSeparator) = &HFF0000
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seHeaderDataSeparator) = &HFF0000
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seHeaderSeparator) = &HFF00FF
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seHorizontalGridLine) = &HFF0000
                SEtablestyle.LineColor(TableStyleLineTypeConstants.seVerticalGridLine) = &HFF0000
            Next
you have to update the window to see the change:
 DirectCast(objApp.ActiveWindow, SolidEdgeDraft.SheetWindow).Update()
The Hatch Style has Color Propety for the lines and FillColor Property:
Dim SEfilltyles As SolidEdgeFramework.FillStyles
 Dim SEfillstyle As SolidEdgeFramework.FillStyle
 SEfilltyles = SEDraftDocument.FillStyles
 SEfillstyle = SEfilltyles.Item("Normal")
 SEfillstyle.Color = &HFF0000 ' blue
 More complicates Hatch styles have addional Propertie in the HathPatternStyle object.
regards Jürgen
JB
SE ST10
Thanks! This worked perfect.
