Change link of (or replace) occurrences.. Revision Manager...?
Hi All,
I have created a template assembly file. I use the template assembly to update and create new file. So i want to use revision manager API to change the link of several occurrences.
How to change the link of a specifc occurrence? Or how to replace that particular part?
I am not getting any help. Does anybody have some code snippet for this?
Many thanks in advance
Posted by: Prasad Pawar
Post date: 12/15/2008 8:38:56 PM
RE: Change link of (or replace) occurrences.. Revision Manager...?
I use VB.net & SE v20
Post date: 12/15/2008 8:48:48 PM
Hi Prasad
first step is create the object for Revision Manager then open the assembly file in which you have to replace the sub assemblies or parts.
define the linked documents like dim linkeddocs as RevisionManager.linkeddocuments
use a loop to find the required sub assembly or part on the basis of path or its name
like for each linkeddoc in linkeddocs and the code to trace specific part or assembly if yes then use replace command and the path with which the part or assembly is to be replace
i can not send the code because i am working some different customization and i am outside India sorry
you can try ask if any problem
all the best
Sandeep S
Posted by: Sandeep Shewale
Post date: 12/15/2008 8:57:12 PM
Thanks for quick reply Sandeep.
I will give it a try and get back.
Thanks once again
Post date: 12/15/2008 9:04:54 PM
its working. Thanks
Post date: 12/16/2008 5:39:49 PM
Hello Prasad, hello Sandeep
The path to the linked document could be changed in Revision Manager just the way you described it Sandeep, but for some reason it doesnt work for drafts... any idea why?
Cheers,
Salwadora
Posted by: Salwadora
Post date: 1/14/2013 8:38:46 AM
