Change the size of the Table in draft...
HI,,
      I want ot change the size of the table in the draft document...
Is it possible in solid edge. If yes a code snipppet or an API will help me a lot.
Thanks a lot.
Posted by: Pritam Dulam
Post date: 9/14/2009 10:44:33 PM
