Change title block via API
how to replace the title block in Solid Edge drawings via API?
ChangeTitleBlock (drawingfilename,newtitleblocktemplate)
Thanks in advance, best regards
Massimo
Re: Change title block via API
Can you please confirm, in title block all text are linked with your Drawing/part property or its normal text?
Bala
what do you want to replace? The complete title block or some texts in the title block?
JB
VS2015, SE ST10
Found this
 objSheet.replacebackground(filenuovocartiglio, bname)
but is valid only for ST9, tehre is something linke that for ST8?
Massimo
Hi Massimo,
since this as new function in ST9 there is no support in older versions.
You could use the windows clipbard to copy from a template drawing to the background Sheet of the current drawing as work around.
JB
VS2015, SE ST10
