Changing Line Color in Draft API
All,
Does anyone know how to change line colors on the fly in a draft drawing view?  I have all of the dvline2d objects in my model members as I use them to make dimensions, but there does not seem to be a straight forward way to change colors.  Any ideas?
~Matt
Posted by: Matthew Daniel
Post date: 11/13/2007 8:18:26 AM
RE: Changing Line Color in Draft API
Matt,
I can look into it for you but I'm not quite sure what lines you're talking about. Can you reply with an example draft attachment and maybe some comments on which exact lines you're wanting to change.
Posted by: Jason Newell
Post date: 11/18/2007 8:46:01 PM
Jason,
Don't worry about it.  I figured out a method.  My solution was to create custom line styles for each color that I want to use and I change the line style on the fly at the model member object.  Seems to work well becasue I can change style at the assembly level.
~Matt
Post date: 11/19/2007 5:21:31 AM
