Changing object color
I have a line created in a draft sheet using
Dim oLine As SolidEdgeFrameworkSupport.Line2d = oDoc.ActiveSheet.Lines2d.AddBy2Points(ox, oy, nx, ny)
Changing the line color using
oLine.Style.LinearColor = 32768
or
oLine.Style.LinearColor = seColorDarkGreen
does not set the line color. Am I missing something obvious - any refresh, update, etc.
Any hint is highly appreciated.
This is working for me! This must be a bug in the version...
This is working for me! This must be a bug in the version you are using...
I am on ST7.
Re: This is working for me! This must be a bug in the version...
Wow! you are on ST7
I too found it to be working and realized it was hasty on my part to post the question, whereupon I deleted this question within few minutes - Don't know how its still alive.
Thanks for your reply though Smiley Happy
