Changing the Open Document/Filename
We have an add-in that is used to sync the part and draft common attributes. When we run this add-in we would also like to have it change the filename. I am having problems finding an API that will let me change the filename/document name of the document (part or draft). We are using SE V17 and VB6. Could someone point me in the right direction.
Posted by: Brian Hemmerlein
Post date: 12/11/2006 8:46:34 AM
