Changing view style in assembly - visible edges
Hello everybody!
I am programming with SolidEdge since a half year.
My Problem:  I am using VB.Net and automatically create NC-Tools. This works really fine, but i cant change the view in the assembly and make edges visble. How can i do this via API?
(Please have a look at the attachment)
Ben
Posted by: Ben Grundler
Post date: 8/26/2008 2:07:18 AM
RE: Changing view style in assembly - visible edges
See attached screenshot from SolidEdgeSpy.
Posted by: Jason Newell
Post date: 8/26/2008 8:26:00 AM
Thank you very much Jason!
I think i should use the Solid Edge Spy more often ....
Great!
Post date: 8/26/2008 10:01:09 AM
Post date: 8/31/2008 11:07:35 PM
Hello Jason,
changing the RenderModeType works fine but i cant get the view i want.
The hidden edges are still visible when i switch to. "SeRenderModeType.seRenderModeSmoothVHL"
I need the view with hidden edges are not visible!
Here the piece of my code:
seapp.Visible = True
seapp.DisplayFullScreen = True
Dim SeWnd As SolidEdgeFramework.Window = seapp.ActiveWindow
SeWnd.Activate()
SeWnd.View.RenderModeType = SeRenderModeType.seRenderModeSmoothVHL
SeWnd.View.SilhouettesEnabled = True
In my attachment you can see the wrong view, please look at it!
Thanks for help!
Post date: 8/31/2008 11:09:32 PM
