Check all parts in assembly or folder for errors
How check all parts in assembly or in folder for errors as incomplete section, missing parents and else?
For checking draft I use macro which check all draft in the folder for outdate views.
I would like similar macros for checking parts.
I use Solid Edge ST4.
Thank you for help.
Lotar
Re: Check all parts in assembly or folder for errors
Lotar,
it's not freeware, but may be an option for you:
As Siemens PLM Solution Partner I developed as part of my FlexSpooler ProgramSuite the application XProof which does exactly what you are searching for.
See the PDF document XProof V2.2 for details.
Kind regards,
Wolfgang Kunert - www.wksyspro.de
How much does it cost?
Lotar
