Check if Layer is Hidden on Drawing Sheet (Not a view)
With VB, is is possible to check if a layer is visible on a Drawing Sheet that has no views on it?
There is the .ishidden option for a layer in a drawing view, but i cannot find how to check if a layer is visible on the sheet.
Thanks.
Clive Coomes
Design Engineer
Solid Edge ST10 (Version: 110.00.11.004 x64)
Laptop: Dell Precision 7530, 32Gb Memory, Nvidia Quadro 3200, Windows 10 x64
Re: Check if Layer is Hidden on Drawing Sheet (Not a view)
@CCoomes,
Function IsSheetLayerHidden(layerName as String, sheet as SolidEdgeDraft.Sheet) As Boolean
Return (Not sheet.Layers.Item(layerName).IsShownInContext(sheet))
End Function
Kind regards,
Wolfgang Kunert - www.wksyspro.de
Thank you Wolfgang,
This works perfectly and is such a simple solution.
Thanks again.
Clive Coomes
Design Engineer
