Check if drawing needs to be updated.
I have written a tool in c# which perform some operations on large amount of drawings.
Its working fine, thanks to help which I have received on this forum Smiley Happy
But now I got new requirement from users, to validate drawings before I perform more operations on them.
Precisely I need to know if drawing needs to be updated (update views command) or not.
I know how to update them automatically but that is not the case, I need to know just if drawing needs to be updated or not and show that info to user.
Does such property exist ?
I was told that its indicated by gray box around element on drawing if its need to be updated, so in theory it should be possible to get that.
Thanks a lot for any help.
Posted by: Robert Ozga
Post date: 5/24/2012 4:55:46 AM
Re: Check if drawing needs to be updated.
You must check each DrawingView on the sheets with the property:
isUpToDate
This specifies whether or not the drawing view is up to date with respect to the 3d model it references.
Posted by: JR
Post date: 5/24/2012 5:44:04 AM
