Circular Pattern for Drawing
PLM World Member Experimenter PLM World Member Experimenter
How to use circular pattern in a Drawing Sheet using VB.Net?
In SDK I found the example use Circular PAttern for Part Documents.
But manually it is possible to use circular patterns in Drawing Sheet.
Please provide any sample code for using Circular Pattern in Drawing Sheet.
Thank You
