Clear Dimension Tracker in Draft
Does anyone know how to clear the list that comes up when the dimension tracker is run on a draft file?
I was using SendKeys to click the Clear button, but it doesn't want to work in Solid Edge v19.
Thanks.
Carl
Posted by: Carl Breving
Post date: 1/14/2008 5:49:28 AM
RE: Clear Dimension Tracker in Draft
Carl,
I don't believe you'll find anything in the API. The only way I'd know to do it is with a hack addin. What I mean by that is, you can watch for the command and when it runs, you can find the ListView control and send a simple LVM_DELETEALLITEMS message to the window. Are you willing to write\support an addin for this functionality?
Posted by: Jason Newell
Post date: 1/15/2008 3:28:45 PM
