Com Register Issue VS 2010
I am getting the following eorroe when i build the VS2010 C# solution in relaese mode even though i enabled the option(Register com interop)
Error 130 The assembly 'NextGen.NextMD, Version=, Culture=neutral, PublicKeyToken=null' is not registered for COM Interop. Please register it with regasm.exe /tlb. NextGen.NextMD.UI
Error 131 The assembly "C:\development\main\Bin\NextGen.NextMD.UI.dll" could not be converted to a type library. Type library exporter encountered an error while processing 'NextGen.NextMD.Templates.NextMDTemplateUIControl, NextGen.NextMD.UI'. Error: Error loading type library/DLL. NextGen.NextMD.UI
Please help me
Posted by: Prabhu
Post date: 4/27/2012 6:53:30 AM
