Convert Parts List to a Table (VB.NET)
Is there any command that enables us to convert a parts list to a table? Here's what I have until now:
[code type=vbnet]
Public seApp As SolidEdgeFramework.Application
'A variable is assigned to the PartsList from the draft document
oPartList = seApp.ActiveDocument.PartsLists.Item(1)
'Send 10659 command (gotten from JasonNewell's Event Spy) which seems to convert a parts list to a table
oPartList.Application.StartCommand(10659)
[/code]
I added an image which shows which PartsList that needs to be converted to a table. The goal in this is to be able to access the information easier and faster. Since I was able to convert a PartsList to a table manually, it must be possible to do it programmatically?
Thank you,
Alex
Posted by: Alex
Post date: 12/11/2012 9:00:10 AM
Actually, that command works! I just need to figure out how to select the part list. If I manually select it and step through the command, it will convert it.
As of now I am trying to select the PartsList (first post's attached image) using:
[code type=vbnet]
oPartList.Application.StartCommand(SolidEdgeFramework.SolidEdgeCommandConstants.seAssemblySelectCommand) 'Select the part list using 45000 command
[/code]
I cannot seem to select the actual part list programmatically. If I do it manually and then execute the command(10659) to convert the table; it works. The goal is to select it programmatically though ...
Help is appreciated!
Posted by: Alex
Post date: 12/11/2012 9:17:08 AM
Great to know, thanks!
As for my previous problem of selecting the PartsList. Here is what I've got (it works!!)
[code type=vbnet]
Dim selectSet As SolidEdgeFramework.SelectSet
selectSet = seApp.ActiveSelectSet
selectSet.Add(oPartList)
selectSet.Application.StartCommand(10659) 'Command that converts to table
[/code]
Thanks everyone for your help. Thought I'd share the answer that me and my colleague found.
Posted by: Alex
Post date: 12/11/2012 10:29:12 AM
