Coordinatesystem in SubASM - Coordinates and angels to Top-Level ASM
I try to get the absolute Coordinates and angles of a coordinatesystem in a subassembly in relation to the Top level asm.
I hava e top-level assembly with subassemblies (maybe a deeper structure)
What I need is the absolute coordinates of special CSs in subasselmblies.
What I can get without problems is the position and angles within the occurrences absolute or relative to the parent it is createt from.
But I found no way to get the values relative to the active topLevel-asm.
Has anyone an idea.
Thanks in advance
Ape
