Copy PMI dimensions from PAR to ASM
if you make a 3d-pdf from an assembly, you only get the pmi dimensions from the assembly displayed in the 3d-pdf, even if you make a pmi view with all the pmi dimensions from the parts displayed.
I want to make a library with some parts, containing  the relevant pmi dimensions, which are placed in diffrent assemblys and in the end make a 3d-pdf from this assembly, displaying the pmi dimensions from the parts.
Is there an easy way, to copy all the pmi dimensions from all parts to the assembly? (simple assembly without any subassemblys).
Greetings from Germany
Christian Kunkel
https://c-k-m.info
Re: Copy PMI dimensions from PAR to ASM
Problem should be solved with an one of the next MP's. PR7812358.
Christian Kunkel
https://c-k-m.info
Hello again,
SolidEdge Development decided, that not exporting PMI-Dimensions from parts when you create a 3D-PDF from an assembly is WAD.
For this reason, i want to copy the PMI Dimensions from all parts within an assembly to the assembly.
In the object browser i found, that the only way to create a pmi dimension is the AddDimension() method from the Dimensions() collection. AddDimension() requires a DimInitData Object.
Is there an easy way to fill the DimInitData() Object with the required information of the parts pmi dims?
Christian Kunkel
https://c-k-m.info
