Copy Relationships Between Occurrences
I have an item in an assembly.
I can find the Occurrence in the Assembly object and the Relations3D for that Occurrence.
I can also add another identical part as a new Occurrence and remove the grounded relation that is automatically set.
I can't however see how to copy relations from the identical Occurrence.
I can see how to extract the data from relations with a view to recreating them but I was wondering if there is a copy process for Occurrences or Relations3D?
