Copy & Paste view, balloons and Partslist
Dear All --
I want to move all the views, balloons, and partslist from one sheet to another. How best I can do this?
cheers
Posted by: Kiran Thomas
Post date: 1/10/2011 1:12:48 AM
RE: Copy & Paste view, balloons and Partslist
All --
I did it.
//Get the select set object of the document
//Activate the appropriate sheet
//Add all objects in the active sheet using select set
//Copy the added data to clipboard using select set
Let us have a new draft, say draft2
//Activate the new draft file
//Get the active window of the activated sheet
SolidEdgeDraft.SheetWindow sWind = (SolidEdgeDraft.SheetWindow)draft2.Application.ActiveWindow;
//Paste the data from clipboard
sWind.Paste();
Let me know if somebody has a doubt.
cheers.
Post date: 1/11/2011 12:32:21 AM
