Copy groups on dft & paste to the background of another dft
hello,
I try to make a programm with VB.
It will copy a group (blocks "aaa") of a draft ("d:\dftstd.dft") and pste to the backround of another draft
( SolidEdgeFramework.Application.ActiveDocument)
I make a lot of test but I always cant select the group "aaa"
I begin in programming and I'm french so exuse my explication and my english
Thanks for the help
PS: I work with SE V20
Posted by: THIBAUD EMMANUEL
Post date: 1/13/2011 10:50:13 PM
RE: Copy groups on dft & paste to the background of another dft
Here is sample VB6 code to get you started.
Select the group and then run the program. Selected group will be copied into a background sheet.
Please let me know if you need more help.
Sub main()
Dim seApp As SolidEdgeFramework.Application
Dim dftDoc As DraftDocument
Set seApp = GetObject(, "Solidedge.application")
Set dftDoc = seApp.ActiveDocument
Dim dftSheet As Sheet
Set dftSheet = dftDoc.ActiveSheet
' Dim grps As Groups
' Set grps = dftSheet.Groups
Dim ss1 As SelectSet
Set ss1 = dftDoc.SelectSet
ss1.Copy
dftDoc.Sections.BackgroundSection.Sheets(1).Activate
seApp.StartCommand (DetailEditPaste)
dftSheet.Activate
ss1.RemoveAll
End Sub
Posted by: Sanjay Kulkarni
Post date: 1/15/2011 11:35:33 PM
