CopyEMFTOClilpboard
Jason,
Your CopyEMFToClipboard routine saved my bacon. Thanks.
However, the code really does the opposite of its name, it's really CopyEMFFROMClipbord...
Do you have something similar, or can you point me in the right direction for actually putting a MetaFile successfully onto the clipboard?
Essentially reversing your existing code?
(and for anyone else posting, no, just using Clipboard.SetImage(metafile) does NOT work.
Eric
Posted by: Eric Robishaw
Post date: 1/30/2009 12:02:55 PM
RE: CopyEMFTOClilpboard
Never mind, found the answer:
http://support.microsoft.com/kb/323530
Eric
Post date: 1/30/2009 12:15:03 PM
Eric,
Glad you found your answer.
Posted by: Jason Newell
Post date: 1/30/2009 8:26:31 PM
