Copying physical properties from an assembly to a simplified part (ST8)
Hi there,
I'd like to programmatically transfer the physical properties of a set of assemblies, to their related simplified parts (nb: parts may be made of surfaces only - no solid bodies).
ST8 copies these properties when saving-as-part a simplified assembly, ST6 did not.
I hope something new has come up with the new version, allowing now doing it out of Edge also...
Thanks in advance!
M.
Marco Saracco | Cad Admin
Rotork Fluid Systems, Italy
Re: Copying physical properties from an assembly to a simplified part (ST8)
Hi there,
found - sorry, with the Call objdoc.PutUserPhysicalProperties (*** list of variables ***)  it works ok!
Thanks anyway!
M.
